I mounted mine where the linkage would normally live. but you'll have to make room in the inner fender for it's length for R&R.View attachment 1715300083 Has anyone used one of these wilwood master cylinder for a hydraulic throw out bearing on a A body mopar?If so where did you locate it on the firewall? Was thinking of installing it where the mechanical linkage normally goes through the fire wall. This seems to be a long way from the clutch pedal, but guess it might work.
Thanks for the pictures and descriptions, will probably use the same existing hole.I mounted mine where the linkage would normally live. but you'll have to make room in the inner fender for it's length for R&R.
My front clip is mounted as stock,, front suspension is stock except for tubular uppers,, Access to control arm bolt is no problem except it must go in from the left. I cut the hole and welded a hammered out, cupped replacement piece to give clearance for the master with room for removal if needed..last shot is on the welding bench before the inner fender was installed.Nice work. Does your entire front clip come off from the car, or how did you get that last shot? Did that dimple affect your access to the upper control arm eccentric nut, or do you have an aftermarket front suspension?
Where did you get your push rod set up, or did you make yours? The one that came with my kit, is not going to work.My peddles ended up even without extending the push rod. Do you think you'll be able to remove the master down the road if needed. That's the reason I made the clearance. I guess our adapter mounts are different lengths.
My peddles and hydraulics came from Keisler, I cant find a pic of the specific kit but you can see here how long the master push rod is, kinda.Where did you get your push rod set up, or did you make yours? The one that came with my kit, is not going to work.
what trans is that?My peddles and hydraulics came from Keisler, I cant find a pic of the specific kit but you can see here how long the master push rod is, kinda.
it's a Legend Gear 700, I don't think they are available anymore??what trans is that?
Thanks for the picture, I am going to pick a longer threaded section. Pretty sure it will all workout.My peddles and hydraulics came from Keisler, I cant find a pic of the specific kit but you can see here how long the master push rod is, kinda.
Will look for it tonight.Do you have a part number for this? I can't find it.
Pretty sure it is this slave unit. Summit racing part number 260-6089. Mine says 0750 on the side of it. That’s the bore size on this unit. Not sure where the adapter that’s mounts to the firewall. Give silver sport transmission a call, they will point you in the right direction. Good guys over there.Do you have a part number for this? I can't find it.
