greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,729
- Reaction score
- 1,457
Do we have to special order this oil or can you pick it up on the shelf somewhere
This is probably the best solution: use an oil with the right amounts, as there will be no incompatibility between additive and oil. Though there is such a thing as too much ZDDP; I've read of numbers in the mid-upper 2000 PPM as being too much.John, I use the Lucas Hot Rod and Classic oil. 2400 PPM of zinc, so no additives necessary. It's about 27 bucks for a five quart jug from Summit. I use it in my truck and I use it for break in as well. I do coat the cam and lifters with a zinc/moly break in lube, though.
Correct. Spring pressure plays a part, as well as how aggressive the cam is designed. You are also correct too much zinc is bad, causes loss of power and deposit build up. 1300 -1500 is more than enough to protect any factory flat tappet and mild street builds. VR-1 10w30 is a great break in oil and a oil to use after break in with FT cams, but the use of the cam break-in lube is still necessary during the break in.This is probably the best solution: use an oil with the right amounts, as there will be no incompatibility between additive and oil. Though there is such a thing as too much ZDDP; I've read of numbers in the mid-upper 2000 PPM as being too much.
And the use of additives has some possible down sides with an additive not working well with a particular oil. I can't say what additives are good with what oils or or not. See here for some VERY generalized info:
Ask Away! with Jeff Smith: Can I Mix Zinc Additive with Off-the-Shelf Motor Oil to Save Money? - OnAllCylinders
FWIW, the need for ZDDP in the engine seems to be contact pressure driven. I have run across research that indicates that lower contact pressures (like on a stock type cam) don't require it as much.
Cool.. a '62 4 door in your avatar!I have not seen any break-in oil sold local to me. I used Lucas break-in oil in my poly solid lifter motor and Gibbs Driven BR 30 oil for my 440 solid lifter motor. No additives needed. Both cams are living well.
Bradd Penn and Joe Gibbs on the shelf locally & at the speed shops near by.Do we have to special order this oil or can you pick it up on the shelf somewhere
