Hydroboost brackets
Funky-
To my knowledge, the only hydroboost hemi's to date have an offset bracket. Hopefully Riddler is able to figure it out mounted straight on!
Riddler,
I got my hydroboost unit last night and I need to know which hardline is the pressure in and which hard line is out to the steering rack. There is one on top and one hard line on the side.
Thanks for your help.
Andrew
Small line is pressure and the big is the return.
I was just going by the pic Riddler posted. Looks like -8 and a -6, but hell, my eye isn't what it used to be. So both lines for a hydroboost are -6 lines?
Sorry my son went to bed after me....
Lots of images of how they hook up online....
Riddler
NP good luck with the setup. If you need anything, brackets, fittings, etc I'll be sure to point you in the right direction.
Riddler
Do you have fittings that convert to AN at the pump & booster so I can get rid of the hard lines?
Andrew
I got mine on eBay for $30 shipped. Each fitting is about $12-14 at summit and they don't make the low pressure drain one.
The beater seller sells all 3 made in America!
eBay hydroboost fittings.
Riddler
