mopardemon340
I have had mu hydroboost for some time now and we really like it. Theres just 2 issues with it that we fixed but I dont think its proper and would to redo it making it proper. Out issues are that the brakes are very sensitive and the steering is very ight feeling. Now what I did to fix the steering was to bypass valve to lower the pressure to help get the steering feeling better. But I dont like the bypass valve and want to redo it all. Right now my MC is a 1 inch.
What size MC should I be using 1.125, 1.25, 1.5?
Front disc rear drum.
If I did the pump it down to the PSP would that help with the steering?
Please explain why I need a larger mc rather then a smaller one if needed to go bigger? I dont understand the logic behind it.
