Valiant69er
Nice project. Some challenges ahead, but it will be cool.
Do you have a trunk pan lined up already?
I'm afeered I'm gonna have to put a quarter on the left side of my Valiant, but I'll cross that bridge when I get there. It ain't nuthin but a thAng, but it ain't happenin right now in this heat. I'm like you. I've done some bodywork in the past, but WAY more mechanical work. I think the best that's gonna happen with mine is, quarter repair panels both sides down low........but "we'll see". lol
Really wasn't that bad to do the 1/4 panel, but if you are going to tackle a job like that, be patient, make dozens of measurements, cut small sections at a time, I cut the old panel in 8 pieces, but by all means get a good mig welder with gas, works far better than flux core crap. Tig is even better, but I have never used a tig welder, so I went with what I know and have. Weld slowly, by that I mean space the contact points well apart to prevent heat warpage, and take your time. You probably already know all of this anyway, so I'll stop preaching now lol.
I left my cuda sitting in my yard under a car cover with no trunk floor, a cat had a litter of kittens in it.Got the heater box out last week, easily an inch of mouse crap throughout the thing. Washed it out thoroughly, cleaned and lubed the cables, tested the fan motor, put a new heater core in, re-assembled it and back in. Found a good (hopefully) used radiator and shroud from a 73 340 4 spd car. Finished up the plumbing, all new hoses, started filling the rad and the lower hose was leaking at the water pump inlet. Checked the clamp, tried repositioning it lower on the inlet, still leaking. I can't see anywhere else that it could leak from, water pump housing was dry, plus it appeard the water was going up from the end of the lower rad hose. Took the hose off, checked for burrs on the pump housing, it's clean, as is the inside of the hose. Tried it one more time, still leaked, so I took the hose off and bought another one on Monday, haven't got it installed yet. Next up is rebuild the carb, re-install the MSD box, and tackle the interior, there wasn't much there when I bought the car, have found some parts and will likely use what I have for now at least get it running.
Thanks, I'm happy with it, she's good and solid.The trunk pan came out good! You got this junk runnin yet?
