So would I. U can still run the solid rollers on the hydro shaft just use less lash like said earlier. KimJust asking here, but why didn't you use a solid roller from the get go? More power all the way around plus the shorter lifter. Please don't tell me it's the frequent valve adjustment thing, as that's just a myth. With all the high end valve train parts you're using here, if you have to adjust once a year, I'd be shocked.
