i think im going to part this 71 valiant
Understood. I dont know what year those changed.
How much for the vacuum operated water valve on right inner fender ?
i think i'm going to try to sell all the a/c stuff together for 200$ or so.i will make a note that you want that piece if i split it up..
mike
Are the tail/headlight sockets the same as a 73 dart? If so and they are in decent shape how much?
i wood like to sell whole harness from front to rear for 100$ and shp...it's very nice!everything worked as it should.i may have the sockets you need on a pos harness though.i'll check and let u know.
mike
What is the part number on the radiator? How about the one against the wall? I need a 2998935. I need the plastic anti-rattle rings in the door tops that the lock knobs pass through also.
3443985 are numbers on rad,rings are there but the prongs that hold em still are broken off.
mike bee
Mike ---
I'm just up the road a bit from you in Virginia ---
I'd like to buy the front seat with the headrests and the door armrest pads.
I will PM you regarding contact info.
Best Regards,
Stew
a/c stuff,and wiring harness is sold!still have seats,armrests,nice tail lights 100$,trunk lid 50$,near perfect hood 200$,four door door panels 25$,225 & 904,carb...holley 1 brl,rad & shroud...all parts are + shp.and located in n.c.28001...cash or postal money order only..thanks fabo!;-)
do you have the stone guards that are mounted inside of fender and in front of doors if so are they black plastic
i do have em and they are in good condition...the ones up in the fenders are metal up until 73,then they went to plastic.i have a set out of a 72 duster also and a 69 dart.pms me if you want any of em.
thanks,
mike
still have a lot of parts left.... gas cap..20$,seats...100$,kick panels with insulation30$,tail lights...100$,and plenty more.6(only 5 pictured)4.5 wheels...50$,radiator with shroud...200$,power steering pump & box,complete 225 and 904....what!..all obo and plus shp.from n.c.28001
Someone has a wanted ad for a rear door and 1/4. Those look like nice 1/4's and they don't repop them
thanks! i will check into it.
drivers rear door is bent some but the other three are good.
i still have the factory gas cap...20$,sold the seat belts and cow....moooo!
cutting it up now..nice frame rails(front and rear),rear and dr.side floor pans,and pile oc misc.parts still left.i'll get some pics soon.heres tha driver side vent box...great condition.25$ & shp.
pmed!
pulled a nice set of e-brake cables out of it,t-bars,lcas,9" front drums,strut rods,cross member,and still have the seats..and a huge pile of shi....crap from it.
this is about as close to perfect as it gets..i would like to get 350$ for all...i do not want to shp.unless you do it all on ur end.
thanks fabo.
