I think my 8 ¾ housing is toast.
Hey FlyFish,the exact same thing happened to me(perches moving)I got them rewelded on(using wet rag for cooling)A couple months later I pulled an axel to check splines for twisting(again)Yes the splines were twisted again.:banghead:I already had plans for peicing together a Dana 60.Upon removal of my narrowed 8 3/4 I noticed the driver,s side perch collappsing and the housing twisting(no brace).So I put my narrowed Dana in with the mono,s/Caltracs.I also decided to improve my driveshaft to a chromemoly one with the 1350 u-joints and 904 yoke(Mancini,s)She,s bullit proof now.Maybe you can find another housing and brace it?Mine was a C-body rear narrowed that I paid $100 complete with .489 case and 2.76,s.Couple pics of damaged rear..
Nice..
Anyone here have 10 x 2 rear backing plates for 8 3/4 want to sell PM me ..
You don't have to lay in bed to eat a good bowl of bean soup ..
So, is the housing toast, or is this something that I could fix?
You could probably fix it, provided the dented portion of the axle tube can be moved back into position for rewelding of perches. I'm sure there is a way to do that. I had similar issues, although the dents were from the U-bolts.
In my case, the housing axle tubes were bent banana shaped, so much so that my tires rubbed the forward portion of the rear tire opening. My first clue was someone's comment that smoke was coming off my tires as I went down the track. When I looked at the housing, I was amazed that it indeed was banana'd with twist marks indicating the pinion angle had changed.
I had moved the springs inboard (002/003 SS springs) without narrowing the rear end. I figured this left a bigger moment arm allowing the tube to more easily bend.
Long story short: I took the housing to a guy in Pennsylvania I read about in Mopar Muscle (or something) who could straighten the housing. He had a "gage" which he used along with a press to straighten. I brought that "gage" home with me. I can now tell if a housing is straight any time I want to mount that "gage".
I subsequently back braced my housing and extended the conventional brace shown in this thread to the tube end. I added some support around the perches, shimmed the pinion angle, and have not had a problem since. So, I think it could be fixed if you desire to do so.
Dana, 4 link, mono leafs, floating perches......see how easy it is for us to spend your money....lol.
Seriously, i love your car and good luck on what ever you decide.
I've seen moly tubes used on salisbury type housings before. Not sure that's even possible on a 8 3/4. I never had your kind of power to break one before:cry:.
One of the big magazines, Car Craft possibly, did a back to back 8 3/4 vs Dana strip test and the Dana was only a few hundredths slower even though it weight about 50 lbs. more IIRC. Don't think you'll lose anything if you go that route.
P.S. looked thru my magazine archive and was unable to locate that article...may have been tossed by now? A google search turned up a post at another site from about 5yrs. ago recalling the same article...said it was HotRod mag. and the dana was a few hundredths faster. So either way, performance wise should be a wash.
Are those the stk perches? and what rpm do you leave at?
Sorry, just saw this post...The perches were standard spring perches (not HD or fully boxed). I foot brake, bring RPM's to 2500 and the converter flashs to 5000 as soon as I hit the gas and take off.
I think I'm either going to do a Strange 60, or do the MO875 with a back brace...both are out of my budget...I need to get the 8 3/4 apart to see how bad it is inside. The MO875 will only be a good option if my pumpkin is still in good order....but I think I will probably just fork over the extra money to upgrade to a dana to make it bullet proof.:angry7:
Is it just me or... it looks like you axle is actually bent???
The axels not bent,it,s just the splines twisted.I guess it looks bent but was holding the straight edge and camera to take a pic.That axel was the first one I bent before replacing it,just to have the next one twist and the housing bend $$:banghead:.Dana with CM driveshaft and 1350 u-joints(904 slip yoke)from Mancini,s.No more bending/twisting :D
I would think your axles are twisted like pettyblu's pictures. You already have the center section. The cheapest way out for you is the MO875 Like Turbodart68 is recommending.
http://www.moserengineering.com/com...5m-housing-axle-package-inch-part-number.html
This is another alternative for you........
I am in the middle of building a Ford 9" for mine and Triangulated 4 Link. I am swapping out the 8 3/4 with basically the same set up.
Labor to shorten etc is my own.
Paid $160.00 for the complete 9" rear end.
$60.00 for new big ford housing ends
$45.00 Back Brace
$45.00 Large Aluminum fill & Drain Plug assy
$80.00 for sheet of .250 Chromoly
Total to shorten with new tabs built by me...... $390.00
$1000.00 for New Nodular Drop out with 35 Spline Spool, 3.50 Gears, 1350 Billet Pinion Yoke, Daytona Pinion Support.
New 35 Spline Axles $350.00
This set up is good for 1200+HP.
Here is what I started with and where it is as of today.
Someone is drinking the turbo kool-aide Hahaha.
I made a jig myself with 4 aluminum pucks and a solid steel 1 1/4 bar. EVERY rearend I have chucked up in me jig is bent, well except the new ones. LOL. Anyways If your handy with a welder you can fix your 8.75 housing for very little money. Borrow or make a jig then weld new thicker tubes to the banjo and weld on the reinforced perches, a back brace, and new housing ends or reuse yours. I have $100 in my jig, the aluminum pucks I madde on a borrowed lathe. I do have a friend that I built one of these housings for his mid 9 second dart and it worked for many seasons with a 1.30 60'.
I thought I had broken the spring perches and bent the axel tube when my pinion angle had moved up by 5°, but after taking it all apart it looks like the axle housing is still strait. I opened it up and looked down the weld seam inside the axle tube and everything was perfectly strait (and took lots of measurements), and the axles/spool look as good as the day I installed them 9 years ago. The only issue was the dent left in the tube from the spring perches getting pushed in.
My question is: after removing the old spring perch can I just weld on my new one? The problem I’m seeing is there is about a ¼ inch gap where the perch is not contacting the axle tube due to the dent in the tube (the tube is a little flat on one side). Is this a problem, or can I just weld it in? I ordered a back brace and Calvert Racing HD spring perches to weld on my 8 ¾, but if this thing is trashed I don’t want to waste my time (and money) fixing it…I’ll just get a MO875 housing or something. The Calvert perches cover a lot more surface area (cover 180° of the axle tube) compared to the stock perches, so they should stay put.
Here are a couple pics if that helps:
Not trying to be an *** here but do you think maybe you could have cranked the U bolts incredibly tight that it may have bent or caused extra stress near the spring perch area upon hard launches?
The reason I ask is because I had a buddy do this with very similar results.
center it up and weld it in then take a peace of 2x1/4 flat steel and go from the front edge of the perch over the top of the tube to the rear of the tube weld both ends then were its on the tube.along with the back brace your 83/4 will be race ready I have dun them like this for a 4speed car leaving at 6000 with the wheels in the air.with no trouble..just trying to help......Artie
I don't think so...The Calvert instructions said to torque the u-bolts to 70-80 foot pounds. I thought that was a little high, so I only did 65 foot pounds.
4spd, 6 grand, wheels up......doesn't get any better then that:).
My concern would be the dent in the tube may now be a weak spot that may not take as much abuse as before.
Although the back brace would probably absorb a good amount of the load.
I don't have experience with Caltracs and i know they don't recommend any other devices be used with them, but the housing is pretty much on it's own with this system and i was wondering if anyone has run a snubber along with them to absorb some of the shock on the housing?
Yes, that was one of my concerns too. I was thinking that it might be ok since the new perch goes 1/2 way around the tube (and is fully boxed) and the addition of the back brace...but I don't know.
This is the perch I'm using:
http://calvertracing.com/springperch.php
Perches look good to me.
I added a line to my last post, what do you think?
dam they must be new never seen them like that its about time but think I would still put the flat steel on it like I described...and I dont think that little dent is going to hert it.............Artie
those are some nice perches. i do like the idea of the strap over the top.
will have to try and remember those for my next one.
You can sand them in and make them fit perfect before you gusset and weld them off if it is a concern of yours.
I think with the housing already soft in the perch area and will also get weaker after welding new perches on.(JMO)I would either weld flat steel in place as mentioned or buy a new housing before it collapses more.It,s up to you and your racing fund.Good luck.
I think mopar says 40ft lbs on u bolts. I have seen people just impacted them on and never had a problem but I guess if they are to tight they will dent the housing.
You can probably get good answers to all your questions by sending an email (or calling) to Dr. Diff at
[email protected]
He doesn't try to sell anything and he replies quickly.
[email protected]
After re-reading my reply above, I need to clarify that my suggestion in no way implies that I think the answers to this thread have not been good. They have all been good and sent in the right spirit. Instead, I should have written that Dr. Diff has probably seen and dealt with this problem before. My bad, and I apologize to anyone who felt offended.
have a url link to CALVERT RACING
Here is a sample from a 9 second Nova that 60's in the low 1.30s. It has a 10 bolt (which everyone says isn't strong enough) with cal tracs and the perches reinforced with some strap steel (cold rolled). Runs hard no problem.
