DodgeLad
Skipped the Light Fandango
but not sure, I don't know how to tell from just looking. It's nearby me and for sale.
I didn't ask because I don't have room to store a parts truck. He did mention it probably needs a clutch. Here is CL ad...What's wrong with the rest of the truck?
You'd prefer the 4-sp over a slant A727 w/lockup?It's likely the 4-speed is the OD unit. If possible, I'd snag everything from air cleaner to oil pan, and radiator to transmission. That can be a nice running combo.
I have pulled car trailers loaded with 1/2 t. 88 slant 4 speed OD truck NO problem ONCE I got it rolling!You'd prefer the 4-sp over a slant A727 w/lockup?
So true. I have a 95 Ram 3500 Cummins, it has a unusual 4:10 gear and OD Auto. 2290,000 mi pulling pretty good trailers. I have to run it in overdrive or it is running tops at 55!! Ha But yes you are correct, that A833 OD the OD is just for cruising!!!! I liked that 88 1/2 slant pickup, last yr for the slant I think.Yup. If you need power 2nd or 3rd will meet the need. If you want to cruise economically stick it in OD. Just don't get on it hard in OD, it's for cruising not pulling hills and heavy weight.
