ID these shock plates
my68barracuda
Indianapolis IN
These shock plates are larger than the shock plates that I have on the 8.75 on the 68 Barracuda.
The spacing on the U bolts is the same.
I am going to be putting these up for sale and I don’t want to steer someone wrong on the application.
1) Are these truck or C body or maybe B body 8.75 shock plates
2) would they fit / work for an A body application?
Thanks
They look to be an under the housing plate when the rear is under the spring. They should have a square top u-bolt to go over the spring as pictured with plates though. The curvature in the plate makes me say the plate goes under the housing not the spring
Didn't 2wd shock plates go under the housing and 4wd ones were on top of the housing????
