Ideas on running slower E.T without throttle stop
Guessing the car is an auto with a manual valve body. Try starting the car in second instead if 1st. If you have a lower stall converter try swapping that. I lost about 4 tenths going that route.
Add weight
Adjust throttle cable so it doesn't get full throttle
Disconnect secondaries
I personally use a The ET Genie which is an adjustable restrictor plate.
Imo......
All the tuning suggestions will slow the car a bit, here and there. But the o.p. wants to slow the car from low 10s (10.20 or so?) to 10.90.
I would figure out how to make the stop the o.p. has, in post#9, work. Most consistent, easiest way to kill a substantial amount of time without altering much else. Just keep an eye on the tune and exhaust temps as GTX John says.
Probably easier than adding 500-700 lbs.
We got it installed.
With the bolt full adjusted, the primaries got 3/4 open and the secondaries less than a 1/4 open....... lets see how much does it slow the car down, from 10.15
