Identify this Hays clutch disc.
cpearce
Edson
Would anyone have information on this clutch disc, or perhaps could reference an old Hays catalog? Hays has been taken over by the Holley group and have no info.
Of course, I realize it is an 18 spline, 11" disc with organic friction surfaces, I'm trying to find out if this disc has marcel or if it is a flat plate carrier? Looks like it mat be a street strip disc?
This is for sale one Province over from me, so far I've not been able to reach the seller for any information. I've also tried numerous searches using the part number on the box and turned up fruitless.
Thanks in advance for the help.
Hays still has a 40-220 available, which is pretty generic it seems. I am sure holley tech would know, or if you can figure out what the 220 vs 230 means in relations to their other clutch lines?
It has a flat plate carrier and looks like a 10.95" disc that is used with a 130-tooth flywheel with the scalloped pressure plate but will work with a true 11" pressure plate with no issues. I have a similar one and you can see that there is no marcel.
