Identify this lifter?
cgfen
Vista CA
From a 69 383, (Sorry for posting in the SB forum, but did not see a R / RB specific forum.......).
Mainly just trying to see if this is Original / OEM / Aftermarket?
I suspect aftermarket since I don't remember seeing the "two tone" look back in the day.
It's Hydraulic and surprisingly there is no oil port anywhere around the circumference.
cheers
Craig
The brown color sure looks like petroleum 'varnish' on the lower end of the lifter where it hangs below the lifter bore; that area never get any wear from the bore to keep the varnish off.
The is a Big Block forum...
cheers
Craig[/QUOTE/]
No pinhole in the oil groove..??? Some companies sold solid cams with "converted" hyd. lifters, there was a solid insert retained w/a clip instead of the plunger/adjuster.
Adjustable valvetrain on that 383?
You are spot on, the two-tone IS petroleum varnish.
So do you think this lifter is original?
Thanks
Craig
