Identify wires
tx70dart
Member
TX
Any help on what each of these wires represent/does i'd greatly appreciate it!! 1970 Dart
MyMopar.com
Refrence section.
Download your year's Factory Service Manual and wiring diagram.
From there you can trace out the colors and proximity to other devices. My bet is because there is a connector it will be simple.
Its the entire rear lighting and gas tank harness. you beat me
Green -turnsignal
brown-turnsignal
violet- tail lamp / markers/license plate
blue- fuel sender
pink and yellow-dome
black -ground
Green -turnsignal
brown-turnsignal
blue- fuel sender
black -ground
Sorry not. Black is tail/ marker
Violet is back up lamps
And this brings up a good point. There is almost NEVER a ground wire in any of these harnesses, and black is likely NOT ground.
Yup you are correct. I went off my memory which isn't that good without looking at any cars or schematics. Shows my age . LOL
