"Idiot light" vs. Oil Pressure Gauge
hotrod swinger
Sooke
Good day everyone and happy Friday!
I've been running my small block with the so called "idiot light" for a couple of years now with no oil pressure gauge. My engine is a hi-po 360 LA that I had professionally built in 2020. I ran a mechanical oil pressure gauge for awhile just to ensure everything was ok, then removed it along with my other aftermarket gauges when I fixed up all my factory gauges a few months later.
I know I could run both but I kind of like the look of my dash without gauges hanging underneath and I'm wondering, do you really need an oil pressure gauge for a street car when you have a functioning oil warning light? Every single time I start the car I turn the key to run to ensure my oil light is working before cranking.
What do you say, leave well enough alone?
i'd maybe fit a higher pressure warning light sender. i know they're available here in the uk so there's no reason you should have issues sourcing one in the states. with a stock sender by the time the light comes on it's usually too late, unless you're just idling in traffic. and that assumes you notice it as soon as it comes on, lol.
neil.
I had just the oil light on Vixen for the longest time. I got curious just what kind of oil pressure she had, so I plumbed in a manual gauge and mounted it under the hood. She idles on the relief valve cold at about 75PSI. Hot she idles about 50 and as soon as the throttle is blipped, you can see the needle stop like a STONE on the relief valve at about 75. I'm like you. I don't like the clutter inside so I mounted mine under the hood. If the light works, use it and don't worry about it.
I like the idea of mounting it under the hood, I was actually thinking about mounting gauges under the hood. It would be nice to have a voltmeter, water temp gauge and oil pressure gauge in there.
I know that these cars came with pretty basic instrumentation but unless you're running a fairly stock engine, I wouldn't feel comfortable not knowing about the oil pressure. All of the A and B body cars I've owned had temperature and alternator gauges anyway.
My solution on my Duster was install Voltage and Oil Pressure gauges in a custom mounting bezel that I made to fit in the uncut radio hole in my dash. I am not running the dash oil light and have bypassed the ammeter.
Here is an oil pressure gauge Plumbed in along with the working electric dash gauge and idiot light. So that is actually showing 3 ways to see oil pressure.
Always like a gauge to be able to see the real pressure.
'89 D100, 318
There are Bluetooth senders that keep the gauges on your smart phone. No clutter under the dash.
I am pretty sure I noticed my oil filter going into bypass mode on cold starts last winter.. the Pressure gauge read 5-7 PSI lower than normal until the oil warmed up a little.. That was on a slant six with 80K. Recent oil pan removal for dipstick soldering, and paint. Valvetrain looked clean when I had adjusted the valves.. The oil might have been synthetic, and I had not owned/driven the truck very long. I should have just changed the filter as a test, but I did not think of it, and changed the oil as well. Problem solved..
My point being I want an oil pressure gauge... AND and idiot light that is bright enough for me to notice...
