redryderr
Spacegrass
well you could just ding it in like mine=headmans
Or fix/adjust the angle of the idler arm to match the pitman angle [by slotting the holes and welding heavy washers snugged to able adjustment ] to correct bump steer, then ding the header accordingly after that.
Just figured while your there.
Are you saying to slot the holes on the K-member where the idler mounts in it, then weld in washers?
