yellow rose
Overnight Sensation
I finally have a chance to check some of the various ignition boxes I have on hand to see how they retard with RPM. At the moment I have a MP orange box, an early 1980's gold box, a Mallory HyFire IV, Mallory HyFire V, Mallory HyFire VI digital, and a Mallory HyFire VII analog.
Tonight I tested 3 of the boxes and these are the results.
Mallory HyFire VI digital box with a Mallory 29440 coil. Model number 685.
-1 degree at 3800 RPM
-2 degrees at 5000 RPM
-3 degrees at 7500 RPM
With this box, if you set your total of say 35 degrees at 3000 RPM, just 800 RPM's later you lose a degree. By 5000, you are at 33 total and at 7500 you'd be retarded back to 32 total.
Mallory HyFire V analog box with a Mallory 29440 coil. Model number 690.
-1 degree at 3500
-2 degrees at 4750
-3 degrees at 6200
-4 degrees at 7000
You can do the math.
Mallory HyFire VII analog box with a Mallory 28880 coil. Model number 667.
-1 degree at 4000 RPM
-2 degrees at 6000 RPM
-3 degrees at 7000 RPM
-4 degrees at 9500 RPM
Again, you can do the math and see the issue with locking out the timing, or not setting your total at max RPM.
I can test these boxes to 12,000 if I want to. The machine will easily go that high.
-1 degree at 3500
-2 degrees at 4750
-3 degrees at 6200
-4 degrees at 7000
