RichB
CherryCuda65
How can I set up a coil on a bench test and get 10-30k volts out of it? So far, I've tried two different coils with a 12v battery and can only get 12.5 volts out of the coil wire.
First you cannot measure it. The pulse width will probably not display much AND MAY RUIN YOUR METER
Second you need a capacitor, if its the older "round" coil we all "used to use."
Don't leave it hooked to 12V for long
Wire it up 12V--------coil+--------coil---------coil neg------capacitor-----to ground
Now take a jumper wire and repeatedly touch from coil neg to ground. Every time you pull it off, a nice fat spark should happen at the tower
"Rig" a spark tester, or old plug at the tower to ground
THE COIL CAN IS NOT GROUND. "Ground" in this case is your battery NEG
No not for that short time. I would not leave it connected for "a minute" but you should be "flicking" it with your jumper anyhow. LOL current? I've never actually measured a coil current draw....2-5 A I'd guess
That is a good idea! The bi-metal heater serves as ballast.we used to use a flasher can when we used a coil in the exhaust pipes worked well.
The cap goes in parallel with switch, not in series. You should also have a ballast resistor in series with switch. Put the ballast where you had the cap. It only takes bout 3ms to charge the coil when switch is on, the ballast limits the current to a safe value.
There are a few good reasons to use a ballast. The ballast will limit the coil current, so the coil test is realistic for normal condition. Without the ballast the coil current can be much higher, and coil energy increases by square of current increase. The ballast originated when 12V replaced 6V, the ballast typically has a value close to coil resistance. Without the ballast, coIL current would be double, with energy 4x. With energy 4x, yeah there may be spark for a sick coil, and perhaps not with ballast.You don't need the ballast resistor if only charging up the coil for an occasional spark test...
