Petzschler
→Welcome backâ†
that looks like an intake leak. just my nickle.
I once had this problem with a gold MP ignition box. It misfired like yours is.I've been having a fair share of issues with a new 408 build in my Dart. There is a miss and pop out of the exhaust starting at around 1800 RPM and continues up around 3200 and tapers off some. I pull the spark plugs and find that plugs 1-2 look like brand new, 3-4 have a little carbon on them and the porcelain is light brown, 5-6 are black, and 7-8 look more similiar to 3-4. Ignition is all new MP electronic with chrome box and new MSD Blaster coil. The carb is a fresh rebuilt Thermoquad. Any help would certainly be appreciated. Thanks!
That does not sound too close. I had mine all mounted on a plate on the passenger side and it misfired.I had to move the coil away about a foot and she then ran fine.Hey Duane,
I been a little busy so I haven't worked through all the other suggestions that were posted earlier. I will certainly give your idea a try. Right now the coil is mounted in the stock location close to center on the fire wall and the ignition box is mounted on the driver's side inner fender towards the firewall. Do you think they may be too close compared with the experience you were having? I will try it either way.
