A couple of things here. I once was told that timing had to advance per 1000 feet of sea level. Is this true. I recently went to an electronic ignition system...is timing the same as with the points and condensor, and lastly, I have found a discrepancy in manuals, one says 5btc and the other 2 1/2 ATC ....can some one please tell me the correct setting for a 273 cid...electronic ignition upgrade at 2600 feet?
Thanks in advance!
Thanks in advance!
