diymirage
HP@idle > hondaHP@redline
as some of you know, i made the mistake of buying a bronco to plow with 2 years ago
in those 2 years, ive had the transmission rebuild, the engine rebuild, the whole stupid truck should be new and dependable
it seems like every time i turn my back to this truck something brakes down
2 weeks ago the ingnition switch went out, so i rewired that
then the alternator went out
now, a few days ago, it has a massive backfire which sucked the choke valve stuck in the in carb throat, so i had to pry it back open with a screw driver
and whatever happened after that i dont know, but it backfires and stalls under load now
i cant even drive the junker around the yard without it dying on me
i pulled the carb off yesterday and found a porous vacuum cap on the back, hoping that was the problem and nope, didnt solve a thing
so, im ready to torch this clunker
