[FOR SALE] I'm back with my dual 3.5" speaker brackets
I used #10-24 nuts and they worked fine. I have the passenger side of the bracket in but cannot reach the driver side of the bracket enough to get the nut on the back. How did you guys access the driver side of the bracket? I'm having a hell of a time getting to it.
I used a nut driver and put the nut into the driver and was able to "feel" my way to get the nut to thread on to the stud. it did take some work but it can be done.
I went down and finally picked up my bracket from the parcel post.
looks very clean and prof done.
Thanks
Got my bracket installed tonight with Polk 3.5" speakers. Sound is awesome and crystal clear. One problem I did encounter was my hose on the passenger side was completely rotted. Got a new one from Autozone and am good to go! Thanks Jerry for the awesome product.
Maybe this will clear up a few questions regarding the OEM speaker mounting screws. They are about 1/2" long, and as best I can determine are #10-24 (checked with my thread gauge.) As I said earlier, they are specially shaped and work in conjunction with a thin, stamped clip to fasten the speaker to the dash. The clip snaps into a slotted hole in the dash near the defroster vent. The nuts are speed nuts.
Jerry
Installed my bracket today using Kicker KS400 4" speakers from Best Buy ($40). Everything looks and fits great. Thanks again.
Scott
Looks awesome, Scott. Thanks for the great photos. Although the brackets were initially designed for 3.5" speakers in my son's Dart Sport, I am finding out by others like you that 4" speakers are working just fine with the 3" holes I cut. Did you have to make any modifications or add any spacers to give your Kickers additional clearance from the dash grille?
Jerry
No, thank you, Nick. Glad it all worked out for you so well (not that I expected any problems...
When you get a chance, could you tell us the Polk speaker model number and approximate price?
Jerry
Hey Jerry,
I didn't have to make any modifications. The tweeters on the Kickers only stick up a tiny bit, so I didn't have to add spacers either. It was a quick and easy job :thumbrig:
Finally took a look at the Duster..do I have to remove the windshield or the dash to put this in ?
ian.
ian.
Nope, not at all. It's all done from underneath the dash. I have some very good photos that I'll post tonight which will hopefully answer all your questions about installation. Hang tight...
Jerry
Grassy, maybe these pics will help illustrate what you are about to get into. Bear in mind that I took these with the dash stripped down quite a bit - glove box, defroster vents and hoses, instrument cluster, heater-A/C housing all removed. However, these will show you how much room there really is under the dash - once you get settled in the floorboard upside down and comfortable and reach your hand up through the maze of wire harnesses and vaccum lines. Overlook what I was doing in the photos (removing the heater-A/C bezel.) I'm just trying to show you what's going on under the dash. Don't worry, it's not really that bad - and you can leave your windshield in place.
You can see remnants of the black, sticky sealant they used to isolate the old 4"x10" speaker from the underside of the dash - that's where the new bracket will go. The middle hole of the three you see near the defroster vent opening is the one where you will find the speaker mounting screw. Obviously, if the defroster hoses are removed first, it will make it easier to get at the screws, but be careful - those original hoses are usually VERY fragile. It probably goes without saying that the shorter the better in choosing the nut driver you will use to remove the speed nuts.
Anytime some of you folks who have already done this installation feel like jumping in, be my guest. It's been a while since my son and I did his and I'm sure I am probably overlooking a handy tip or two.
Jerry
Although the brackets are cut with 3" holes, initially to accomodate 3.5" speakers in my son's Dart Sport, it appears that 4" speakers work just fine. Several of you have reported to me that you intend to use 4" versions (or have already), so I bought a pair of my own Volfenhag ZX 834-R 4" two-way speakers to use as a test.
As you can see below, they fit snuggly on my shortest bracket used in '64-'66 early A-bodies and '64-'69 B-bodies, but they do fit. Also, the speaker cones' rubber surrounds do not come in contact with the surface of the bracket. They even fit better on the longer brackets for '67-'74 A-bodies. This greatly increases your selection of available speakers to choose from. I can't "speak" for any other brands of speakers, but the 3.5" Volfenhags in Aaron's Dart Sport have served him faithfully for approximately 5 years without problems.
Here is a list of some of the speakers you guys are using:
Pioneer TS-G1043R 4", Kenwood KFC835C, ES3.5XV.2 The Powerbass Evolution, Legacy LS328, Kicker KS400 4", Rockford Fosgate P132 3.5", Polk Audio DXI 350, Volfenhag ZX 832-R
Got mine yesterday and fit perfect and very nice piece. Highly recommend.
Thanks, Rick
Glad you are satisfied. As you can see in my photos above, 4" speakers fit snuggly on the shorter early A-body bracket I offer, so I expect your 4" Kickers will fit nicely on your longer later A-body bracket your car uses. Did you remember to take some pics during your installation. Was the swap easy for you?
Jerry
Mine was pretty easy.had instrument panel and glove box out.Went in from guage side and slid right in. 4" kickers fit great. thanks
I am interested. I was looking to fabricate something to hold a pair of 3 1/4-inch Infinity Kappa coaxials where the original speaker would go. Please send me more info. Also, does anyone know where I can find an early A-body speaker grill (60-62 Valiant/Lancer)? My project is a 62 Valiant 2-door hardtop.
Can you (or someone else who knows) confirm for me the distance between the two end mounting holes of the OEM speaker. Hopefully, it should be approximately 10-9/16".
Jerry
i want to get one for the 75 dart...do you know if the brackets will fit the 76 ramcharger too?
Hi, Gnome
To be honest, I have absolutely no experience with the Dodge trucks or Ramchargers. If one of the brackets I currently make doesn't fit the Ramcharger, I would love to have someone like yourself provide some basic information so I can develop one that does. Are you game?
As for ordering one for your Dart, please refer to THIS EARLIER POST where I give the link to a form you can submit with all the necessary vehicle, shipping, and payment preference information that I will need.
Thanks for your interest,
Jerry
Hi, Gnome
Jerry
sure! i think i can pull it out this weekend and give you some measurements :)
do you have dimensions for your current ones?
a scan for a template on an 8x10 sheet of paper you can see at the bottom where the paper ends on the sheet.
let me know if you need more or better pics
I know this is a site for A-bodies, but some of you have more than one MOPAR vehicle, including trucks. Therefore... I worked up a new dual-speaker bracket for Gnome's Ramcharger and can now offer them to the rest of you who have a Ramcharger or truck that has the 4"x10" dash speaker. See attached photos showing Gnome's installation. The prototype bracket was cut from an old street sign, which explains the bright colors.
I am getting ready to order another batch of car brackets from my supplier and I would like to get a feel for the level of interest for any of these new truck brackets - I may go ahead and order a few this round, just to have on hand.
Send me a PM if you are interested,
Jerry
