Fabo member Lee Robinson parts out the sheetmetal on these old A bodies. He drills the spot welds and surgically dissassembles them. He is in So Cal. Land of rust free cars. He may not have a barracuda, but he may have darts. These are parts that are the same from ALL other A body cars that will fit your 69 barracuda. It's by no means a complete list, but covers major parts this includes more door donor cars. Dart, demon, duster, scamp, valiant, dart sport, barracuda.
BTW all A body transition pans 67-76 are the same. Ditto for inner wheel houses.
Main floor pan, rockers, and outer wheel houses on 67-69 barracuda are the same as 70-76 duster, demon, dart sport
67-69 trunk pan is the same, gas tank filler pipe hole changed in 70 to 76. The AMD trunk pan is stamped with the 70-76 hole. Will fit, just need 70-76 floor grommet
Front and rear frame rails are all the same from 67-73. After 73 the ends are different for 5mph bumper shock mounting
Trans torsion bar crossmember fits 67-72. 73-76 fits but uses a different trans mount. Earlier mount may also fit later crossmember.
Front nner fender wells are the same 67-72. I believe they changed em in 73 to accommodate a charcoal canister on the right side.
Rear framerail tie bar 67-76
67-76 A pillars ALL 2 door hardtop
Rear shock upper crossmember. 67 one year, 68-76 all the same (all interchange)
Spare tire mount bracket 68-76
Radiator upper , lower, side supports. Later models came with a 26" radiator 67-72 were made for a maximum width 22" radiator
Cowl plenum w stand pipes, and FWD door hinge support panels are all the same 67-76.
Upper cowl panel is the same 67-76 for everything except demon, duster, dart sport.
Firewall fits from 67-72 non A/C and a different one for A/C cars.
Barracuda specific sheetmetal that you can buy new.
Trunk extensions
Quarter skins (year specific)
Rear valance
Front lower valance.
Dutchman
Inner fender splash shields
