I'm looking for Floor Pans
depending on how factory you want them to be.Rockauto has some decent ones and some cheaper ones with less factory bends while auto metal direct=AMD has some that are spot on but they come with a higher price.
BTW you posted this in the for sale forum not the parts wanted forum.
The rockauto ones are just the floor pan where your feet sit (either side). I got the right-side one (~$55) for my 65 Dart. It has just a few rough bends, not very close to the original pan, and the ribs don't match. I had to cut-out a bit up the tranny tunnel, so had to beat a matching bend in the pan with a rubber mallet. Took me about a day to cut and fit (over and over). Still haven't gotten to welding it in since de-rusting and painting first.
Yeah the $50ish ones from rockauto have less factory bends.I got the $70 ones made by sherman are stamped and they are pretty close but not a complete match to my car.they seemed to be deeper than the original pans and was higher at thedoor side about 1/4 -3/8.can't tell now but everything else lined up perfectly.
There is a member that will give you a discount on AMD stuff, if they make them...don't remember his name but I will look for the paperwork....
Sherman nor AMD make pans for the early A bodies.
