d55dave
I am in the middle of rebuilding a '65 727 for a friend. He is putting together a big block '64 fury and wants a slip yoke cable shift transmission ('65 only) to retain the push buttons. He supplied a big block cable shift case and I found, from another friend, a small block '65 727 to harvest some internals from.
The small block trans came from a fury that had been parked (was running when parked) since the late 70s or early 80s. Everything in the small block trans looked great until I got down to the sprag clutch. I was really surprised to find that one of the sprags had rolled into the adjacent cavity, and a few of the springs and fingers on the retainer were deformed. Also there is a crack in the case directly above where the dislodged sprag was. The inner race is all brinelled as well.
I have often wondered what fails first in the sprag, does the outer race tear loose? I would say not based on this transmission. It appears that there is enough flex in the case allowing the outer race to move away from the inner far enough for the rollers to jump into the next cavity.
Man.... I dont think this trans had much time left..... and yes, I am putting a new bolt in sprag from A&A into the big block case.
