JDMopar
If the 318 is the numbers matching block for your Duster, you might save it for a conversation piece. Who knows....1 sleeve might save it.
Which is why I clean one up regardless, instead of just pulling the plug. I want to see ALL the carnage. Because if it is just one, and it's the only one I have, it will get repaired.
And I would have had to have saved that S shaped rod she found for a paper weight! LOL
Yea, maybe it's my fault, he doesn't have a method, I told him to knock the **** out of the piston to get it out, so he did. He has bench pressed me draped over the weights before so I should have known there is a such thing as too much on engine parts.I agree with RRR about putting an eyeball on your cousins method. If I've got a motor that is stuck tighter than a drum like that, I spray the cylinders down with PB Blaster, and let it set a while. If it still won't budge, I will put a short piece of a 2 x 4 in each cylinder, and give it a whack to shock the stuck rings loose. No need to keep frailing on it. Always make sure to take the timing chain off beforehand too. I took a 225 apart for a little science project I'm working on, and it was stuck bad. Took the chain off and it rolled over. I like to have never got the cam beat out of that thing!
1st thought was the valley looks like a landfill. The lifter bores could be all pitted.Gosh, I guess a lot of yall can pick and choose. I've never had that luxury. I've cleaned up worse blocks than that before. You know, some people get great satisfaction bringing back something from the dead......even if it is something there's a pile of. It'a a lot of fun and very rewarding. Yall remember what that 400 crankshaft looked like I soaked in vinegar? A stock stroke 400 cast crank most people would have thrown away.
Got through reading .It's entirely possible.
