While the block may not be the discussion it has to be considered, because it's the foundation of the build.
A lot of guys will run a short fill to strengthen block. I've wondered if a mid-plate along with a front plate would eliminate block flex. Over the years I've only seen a couple factory blocks fail and both cracked a cylinder up and down and both were high hp n/a builds.
The 408 I mentioned was 10.8-1, 260/264° @ .050", .626/.633 flat solid, Edelbrock's that flowed in the mid 290's @ .650", 950HP on a deep ported Victor and 1 7/8" Hedman's. It liked being shifted at 64-6600, anything lower, or higher it would slow down. IMO it had plenty of cam but was running out of head.
The current 434 has a R1 block, ported 360-1's that flow low 300's, ported Indy intake, 1000+ 4150, 11.2-1, 266/271° @ .050", .711/.719" solid roller and the same 1 7/8" headers. It made peak power on the dyno at 6750 and has ran 6.25 @ 110 in the 1/8 at 3292#, it only ran 10.00 @ almost 135 in the 1/4. I normally shift it around 7200, however on the 6.25 the 1-2 shift was 7800, don't ask me how I did it.
This is not really a good comparison, but it does show that even though second engine is 26" larger, with better heads (and cam) it makes peak power at higher rpms. If the 408 had the top end off the 434 I'd guess it would make peak power around 7500 rpms,
if the cam could support it. Add the SR out of the 434 and it may be near 8k.
This and $1.75 will buy a cup of coffee in some places.
