Rodzilla
I have a set of Indy 360-2 heads I'm installing on my stroker. How the heck do ya get a socket on the nuts of the 2 which are second in from each end on the intake side? I am running ARP studs, the socket size is 3/4" for the nuts and right now the only way a socket is getting on those nuts is if I remove a spring. And I don't really want to do that if I can help it. Grind a socket down to clear? Probably won't be sturdy enough to torque with after. Ideas anyone? Thanks
