INDY 'modman' 2x4 intake. How much would you spend if...
ValiantS
Shelby, Michigan
If INDY were to remake the BB WEDGE MODMAN intake, drastically improving it's performance AND it were available for either standard or MW port and B or RB. Where you could use either AFB's or 4150 Holley's. Would $1500 be fair for an intake that would require no modifications to get significant improvement over your single 4150 combo? I'm open to input as to where there is a market for something like this. (e.g.- MW low-deck would have the biggest market, etc)
proto 1
I think 1500 would be fair. That said.....and I'm being serious, not a smartass......what do YOU have to do with Indy? Will input from members here have a real impact? I've read that the new owners are some really nice people. Even though "I" would likely never be able to afford anything, I think it would be a huge plus for those who could, as Mopar seems to always be the one every leaves behind in terms of performance parts.
pro6 There are a couple tweaks I'd want to do with the spacer/top/lid. But overall I think this is a significant improvement for this intake and the cost isn't bad especially if you want the cheap AFB's. This has already SHOWN almost 800HP in the car.
If you look at he evolution of the protyping I decided to straighten the trajectory of the runners which required cutting back the runners at the bend and adding material to the orig design runner extensions...
I'm just a guy that has their ear on this currently. I did this as a 'fun' concept on a motor I did for a NSS car. This was and still is being used on a 486CID low deck engine. I did so much rework on this I branded it the "SEANMAN".
Very cool. Thanks for this! I hope they listen. I think it was @PROSTOCKTOM that was JUST asking about such a piece for the standard port heads.
I need to edit this post of mine and say "if I had the money I would definitely buy one how you designed it" but I can't afford big ticket items like $1500.00 so that awesome intake would be sold out before I could get one.
That's why I have to modify my own stuff but I will say to you Sean, you are a very smart and talented hot rodder.
The stuff you do gives me ideas & I thank you for that.
Nice work!
I am toying with the idea of a Modman for a new gen Hemi build, the biggest deterrent is the cost. These used to sell for $599 plus the top, it is now $1089 for the base and top. Factor in the dollar conversion currently and it quickly becomes a $1700 manifold.
This is nearly exactly what I was discussing with some freinds.
The OEM ModMan runners are too short IMO. While a short runner has its place….. these are very short.
That is some really nice work. Seriously, very nice. I love the direction.
To answer your question, yes I think $1500 is pricey. It’s out of my range of willingness to spend on for my applications. A very serious “For the Money” racer may drop that amount quick, not I.
I know the recent inflation disaster is giving the dollar a trouncing causing these higher prices and it is REALLY hard to ask someone to take less money that they should be getting for their product and more so there time and efforts in developing efforts. It’s just simply being honest that IMO, $1500 is a bit much.
Thanks! The fit and finish internally isn't as perfect as I would normally do but it was getting to be $ time-consuming$ and I wasn't being paid for it. I do feel it proved itself however. Just like anything else, the second one would take much less time and be nicer.
Nice work!
I'm not familiar with the hemi MM but one person has reported it not being so bad. Take that for what it is.
I really like what you're doing with that manifold. I also rolled the idea in my mind that the manifold could be improved on and end up being a nice piece. But I no way have your fabricating skill but you got my attention!
I have a nice update on this manifold. It's been frustrating for the both of us because the motor wasn't running what we expected but I was very confident it wasn't because of the intake. So, Scott tried some different AFB's that were known to be good, where these carbs had a sketchy history. The car picked-up .2 and 6 mph from a outing 2 weeks prior with just the carb change and the weather was worse. There are still improvements to be had because the runs were made without the airpan. But it's a new best of 9.61 @139 in 3400ft DA weighing 3420# This is showing 12% converter slip as well so, I'm very happy.
Is this strictly a race piece or is it something that would be streetable with the right supporting cast.
That car hauls some *** and it’s so damn cool
I'm sure with the runners being longer now it'd do well in most applications. While the runners are shorter than the longer runners on a typical single 4 intake, they are now all the same AND likely the center 4 are at least as long as a typical single 4. With two carbs and the plenum being 'fixed' distribution will be inherently better.
The 4-door body is growing on me SOMEWHAT but, I'm about the performance. Guess it got some good compliments over the last weekend. Thanks, I'm satisfied. Now I would be interested to see if it'll out-perform the INDY Tunnelram but that would require a dyno session to streamline what you'd do for the car to benefit. Not sure how much he'll chase any hoodscoop and airpan issues but there's something to be gained there. I know there's a lean-spot in the data at the hit, which you'd expect footbraking with very little pumpshot, and he's willing to chase after that. He said he was having traction issues so he didn't bring it up on the converter as high as possible. He was index racing so braking and driving the top end etc. And he mentioned as the weather got worse the car ran better...
My only experience with the mod man was the single carb version on a customers gen 3 hemi. It was awful. Replaced the manifold with the mopar performance intake and it ran great. It looks like what you have done is what I guessed at the time it needed. Hats off to you for putting in the work. I know where there are a couple gen 3 versions collecting dust if you're interested.
Nope lol
