[SOLD] Indy/RHS LA-X heads and assorted Comp Cams springs, etc.
Locomotion
Florida
* LA-X RHS/Indy heads 20301 NEW bare castings - Cut for 1.92"/1.625" valves. Modify yourself or at own machine shop instead of buying an assembled set and re-doing it. $775.00 for the pair.
* Comp Cams 6024-8 intake and 6026-8 exhaust valves - $125.00 for full set of 16
- 1.92" in. & 1.625" ex.
- Stainless Steel
- .313" stem
- + .100 length from std. Magnum valves (5.01+")
- pics available
* Comp Cams Single Springs 926-16 - $70.00
- 109lbs @ 1.800"
- 317lbs @ 1.300"
- Spring rate: 415lbs/in
- Coil bind: 1.140"
* Comp Cams Steel Retainers 740-16 - $45.00
- For above springs
- 1.437" diameter
- For 10* locks
* Comp Cams Beehive Springs 26120-16 - $170.00
- 155lbs @ 1.880"
- 377lbs @ 1.280
- Spring rate: 370lbs/in
- Coil bind: 1.230"
* Comp Cams Beehive Springs 26918-16 - $165.00
- 125lbs @ 1.800"
- 367lbs @ 1.160"
- Spring rate: 373lbs/in
- Coil bind - 1.100"
- [color:"red"]2 sets available[/color]
* Comp Cams Steel Retainers 795-16 - $45.00
- For above beehive springs
- 1.096" diameter
- For 10* locks
* Comp Cams Valve Locks 623-16 - $25.00
- LS1 style
- 7* locks
- For single "round" groove 8mm-5/16" valves
All items are new. Some have been opened only for inspection or mock-up.
Prices do not include shipping from Florida.
