Indy RHS X heads
bdusted440
machesney park
So I have a set of these heads and I need two valves one 202 intake and one 165 exhaust for magnum heads . I've talked to both company's and am getting the run a round. any idea where I can get them?
Take them to a machine shop, I could not figure out the what valves to buy either for a set of eldebrocks I had.
Dunno if this will help:
Hughes ID's these as 5/16" stem SS valves for their Indy MA-X heads.
Hughes Engines
Then they speak of 8mm stem valves for the LA version.....a critical difference of .0025". So I'd precisely measure the stems and go from there.
Hughes Engines
found the original supplier with help from todd at the hot rod shop. Have them on their way. thanks guys.
