bvt69dart
Technically Challenged!
USA Indy T/A heads for small block
Selling the heads I bought used from another member. (going another direction) I have the rockers and shafts which will be included, set of both 1.5 and 1.6 ratios. Ordered them with the bigger 2.055 valves and added spring cups as well, good for over .700 lift. Asking $2200 BO. Buyer pays shipping from Denver, Co.
Head: Indy T/A
Intake Port Volume: 175cc As Cast
Chamber Volume: 63cc
Intake Flow: 275 @ 0.600 As-Cast (306 @ 0.700 Full Indy Porting)
Exhaust Flow: 182 @ 0.700 As-Cast (197 @ 0.700 Full Indy Porting)
Intake Valve Size: 2.050
Exhaust Valve Size: 1.600
Rockers: Indy Offset, Intake
Bolt Pattern Intake: Standard LA-Series
Bolt Pattern Exhaust: Standard LA-Series
Bolt Pattern Deck: Standard LA-Series
Read more: http://www.moparmusclemagazine.com/t...#ixzz2kjOHZt9d
Head: Indy T/A
