So our car (72 Valiant) is almost done, we are finishing up a few last minute things. I thought I'd give you guys an update. I'll post some pictures on
http://www.facebook.com/dudesexmachina (dudes Ex Machina)
72 Valiant with a bad Master cylinder, bad radiator, bad thermostat housing, fried 12 vdc power line from starter solenoid to dash. $75
The car came with the thermostat housing so that was fixed first, then we found the bad radiator. Found a rambler radiator in the JY for $50. Its bigger and we just have to put on on a longer lower hose.
we are adapting hose onto the transmission lines, and routing those to the AC condensor coil for transmission cooling. about $25 in parts
Transgo Shift kit (#2) $65
Junky Yard E250 leaf springs $90. We flipped the shortest (thickest) leaf and clamped the pack back together and installed it. Had to drill out the front mount to hold the bigger bolt for the E250 leaf. The back spring rate is now about 350-400 Lb/in
$45 of 1.25" .120 thick steel tube, 2 x 33" sliced lengthwise. Then rewelded over stock Slant 6 torsion bars and welded at the ends. New front spring rate is about 410#/in (calculated)
we have V8 bars and coil over springs with adjusting collars as a back up.
Datsun 510 front 7/8" sway bar - Free
Sway bar mounts from Speedway $15
Ubolts and plates for sway bar mount $9
Threaded rod and some 1" angle steel welded to the rear frame outside for the sway bar linkage $5.
8 used shock top rubbers and washer for the swaybar to linkage attachment - free from auto shop
Had to weld the ubolts to the axle to prevent the mounts from moving, after being located to the rear a bit to clear the diff.
99 mustang front sway bar ~1.125" - free (a take off for a bigger bar)
2x4 steel box, some end plates, and nuts and bolts welded to the front part of the cross member hanging down about 4" for sway bar mounts. $25
4 heim joints and some threaded rod for the linkage. The upper heim joint is sandwiched in the LCA. $35
new 1973 MC (brakes do not count toward the $500 limit) $45
Carbotech XP 8 pads for front brakes $165
12" rotor brakes from the 75-79 Mopar M body (I think that is right, the 78 Cordoba or Dodge Monaco cop brakes) $250
74 duster upper Arms $90
off set bushings for upper A arms $50
ATE Blue brake fluid
Summit Racing Brake proportioning valve from the previous HondAcura car. Mounted to the Trans tunnel at drivers right. re-routed the rear brake line inside the car and down the center tunnel to P valve.
1.5" Thick 5x4" to 5x4.5" adapters for the rear wheels $90
1.25" thick 5x4.5 to 5x4.5 spacer/adapters for the front wheels $60
16 x 7.5" Lexus wheels with the centers drilled out with a 2.75" hole saw and filed out to fit on the front hubs (2.815") $250 (used set)
205/50/16 Yokohama S drive 300AA tread wear tires at ~$120 each (these are our rain tires)
16x8" Dodge Steatlh wheels with the centers also drilled out $60 (used set)
Falken Azenis 215/45/16s 200AA treadwear tires at $145 each for dry race tires.
Custom built roll cage meeting 24 HoL and Chump car specs, with an added Dash (knee cap) bar, a NASCAR driver door bars (extends into drivers door), a single passenger door bar, and a middle roof bar, $1700.
our old Sparco Evo Plus 2 seat installed on some custom seat mounts welded to the floor, rocker and center trans tunnel.
Costs against $500 limit $453
wheels, brakes, tires, safety gear $3870
