1969dodgedart Big Block 440 Joined Aug 15, 2012 Messages 279 Reaction score 409 Location Ontario,Canada Sunday at 1:40 PM #1 Looking for information on tail stock movement, ie : how much and stock rubber vs poly difference ?
Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member Joined Jan 31, 2010 Messages 7,058 Reaction score 5,777 Location Cleveland, Texas Sunday at 8:37 PM #2 As the rubber mount ages, you get more movement out of it as the rubber fatigues. I run the later model cross member with a poly bushing. Now keep in mind, my car is race only with a motor plate and mid plate.
1969dodgedart Big Block 440 Joined Aug 15, 2012 Messages 279 Reaction score 409 Location Ontario,Canada Sunday at 8:53 PM #3 Thx for info .Mines brand new rubber with original cross member , seems like it's moving more then it should. May change to a poly.
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,596 Reaction score 14,159 Location Berlin,N.J. 08009 Sunday at 8:55 PM #4 I've read numerous times about the poly mounts causing vibration. not sure if they don't absorb vibrations enough or just throw off the pinion angle. Last edited: Monday at 6:31 AM
