74360duster
JEREMY
here is some info on the new duster i just agreed to purchase today. pictures to come:
75 plymouth duster
471 stroker big block,600 horse power
only 100 cruising miles on new motor,
471 eagle rotating assembly,venolia pistons,13.1 compression,fully grooved mains,milodon 7Qt oil pan,fluid damper internal balance,
cam 471 bore 4.375 stroke 3.9 lift 640,edelbrock rpm aluminum heads.mopar m-1 single plane intake,csi billet water pump,
msd billet aluminum distributor,msd 6al ignition box,mallory pro master coil,full frame,big block torsion bars,
drive train: 727 trany w/reverse manual valve body,10"3500 stall speed converter,275-60-15 BFgoodrich comp t/a drag radials
rear end:8 3/4 sure grip rear end with 410 gears with moser axles,
interior:new carpet interior in excellent condition
75 plymouth duster
