inherited dodge dart swinger
If your budget is 5K/six months-
5.2/5.9 Magnum swap.
If your budget is 15K or more/2 years-
5.7/6.1/392 swap.
...if your budget is less than 1500, you can probably find a running 318 someone else is swapping out or has saved from a parts car because it ran good.
I sold my last 318 last year for $300 it was overhauled and ran good solid compression 125 psi across all cylinders. I sold it to a family member and just wanted the price of the internals at the time I purchased them years before...point is a runnimg 318 should be had for sub $500 IMO
Consider a rebuilt 318 that is a direct replacement - less hassle and even comes with a warranty. Seems a lot easier if you're not into solving puzzles and doing fabrication.
I've had a succession of 70 Darts with 318s - bulletproof and easy to maintain. My current crop:
Day 1. New battery and hold down. Checked/re-gapped plugs. Bought new alternator. Reinstalled freeze plug. Working on oil change. Need to flush coolant system.
