dartslantsix
I'm still trying to track down some issues with my Magnum swap.
I am wondering if there are differences in injectors by year. My engine is out of a 94 Grand Cherokee. My PCM is out of a 95 Ram with manual trans. When I look at Rockauto those two applications do not use the same injector part number.
If they have different flow rates, it could explain an issue I am having.
I found the following list via Google, but I don't know how accurate it is:
5.2 V8:
'93-'94 #53007809 22.7lb/hr @ 39psi
'95 #53030262 24.6lb/hr @ 39psi
'96-'98 #53030778 23.2lb/hr @ 49psi
Magnum injectors flow rate by color?
Can anyone shed light on this?
5.2 V8:
