Hi Guy's,
I need some input on what set up I should be looking at running. At the moment this is what I have.
360 + "40" V8 hyper flat top pistons
Comp cam 227-4 hyd .525 lift
J heads ported polished 2.02 inlet 1.65 Ex double springs
Roller rockers 1.5 ratio
Edelbrock Performer duel plan inlet manifold
750cfm vac sec carb
custom 4 into 1 headers with 2 1/2 pipes & straight though mufflers
Accel electronic dizzy & super stock coil
Trans
727 auto
2500 stall
stage 2 shift kit
HD cluches & bands
Rear
3.9 to 1 LSD.
Tyres
M/T street slicks 235 60 15's
I have added spring clamps to the front section of the rear springs
& fabricated & welded in a set of chassis connectors.
This set up has run 12.911 @ 103.89MPH.
I have purchased an Edlebrock RPM air gap for it.
Now the big question is what carb would you recommend I use ??? I know most racers run double pumper carbs should I change or stay with the vac secondary carb.
& my second question would I benifit from adding a MSD 6-AL.
All help greatfully appreciated
Thanks Oz
750cfm vac sec carb
Trans
727 auto
2500 stall
stage 2 shift kit
HD cluches & bands
Rear
3.9 to 1 LSD.
Tyres
Thanks Oz
