MOPAROFFICIAL
Oogliboogli
Exactly.In regards to cylinder pressure, yes, more duration will reduce cylinder pressure, but so will more LSA.
Yes, LSA has more effect than just cylinder pressure. It broadens the power band, helps idle quality and often will increase peak HP, but the OP can run a tighter LSA and keep his cylinder pressure up.
