Headliners are pretty much straight foward. I have come up with a few tricks over the years. I put the bows throught the listings and pop them into the roofrail. Then I use push on windlace to hold it on the sides before I start glueing anything. I do all my cuting, stretching, fitting and so on, then I remove the push on windlace and start glueing. Before I started using the windlace I used clothes pins which will also work but with the windlace you can hold the entire side tight. Also, either take measurements for the coat hoats, seatbelt ancors, sunvisors and so on, or you could just put a piece of tape under the holes you need and use that as a guide. Once everything is glued, install your mouldings, visors, coathooks and you are done. Be careful when cuting the hole for your dome light and wireing...remeber smaller cuts can be made bigger, bigger cuts can't be made smaller. Also, are you installing any insulation to the roof first ? I have intalled dozens of headliners useing this technique and have been happy with the results....good luck.
