meathead66
Mod Top
This is the thread I followed by youngun as my Painless kit is exactly what he used.
Painless wire harness install (MORE PROGRESS)
provided the guy with the harness for sale didn't buy one of the overpriced harnesses like a yearone that i think runs up to about 1k then i say go ahead and buy it if it doesn't create a money issue for you. Maybe you can get it for 200.00? I think that would be a deal. I installed the ron francis xp68. Connectors are gm but there's really only a couple of places that comes into play most notably the steering column and you need to keep your connectors for wipers. I decided to go ahead and replace everything with new in an effort to eliminate future issues with old wiring and connections. Knock on wood i will not have any electrical issues for a long time. I had never rewired a car before and had it finished after a a weekend of long hours followed by a week working on it for a couple hours a day. IMHO connectors alone in a few places does not justify paying upwards of 500.00 more for another harness. I think ron francis has added more mopar specific harnesses, but almost all these aftermarkets are going to have some gm components (headlight switch) and connector. It's not IF you will have electrical issues it's WHEN. I also deleted the bulkhead connections...put a plate over the hole and passed through a grommet. updating the wiring was my first priority since i will keep my vehicle for many years for my kids.
So, still on this topic....
But got to thinking, is there significance in sharing I have removed the OEM cluster and went with Speedhut full setup?
So, IMO, the only real threat that remains is the bulkhead connector, correct? So is it far more feasible to rebuild (or bypass) the bulkhead since this is the only remaining real threat? Or does the cluster and BH just scratch the surface on potential electrical problems with most A Bodies?
new gauges will not make much difference. i happen to have speedhut too-good stuff. bulkhead is a major component to wiring issues, but remember all the connections and wires are old. once you multiply all the minute components of ageing connections and wires with increased resistance etc. The thought briefly crossed my mind to disconnect the bulkhead connector and restore with a small file/brush/chemicals but with all things considered i decided to go all new and hopefully not need to experience problems in the near future. there are other things you can do for a healthier wiring/charging system such as using relays, etc. but the ammeter bypass and BH wiring are a major source of problems. me, i had the time and bought my kit on sale at the time so went that route. depends on the shape of you existing wire and connections. side note:i know when i pulled my wire tape off, the wires were like crispy ramen noodles. some people look at it real quick and say..."my wiring looks good"...but i recommend going deeper like unplugging things and peeling back the loom. some do many don't.
Just scratches the surface. Most guys are adding electrical components that weren't considered when the car was built (stereo, elec. fans, fuel pump etc.).
The added elec. parts requires more power, so adding a higher amp. alternator is necessary. The added amperage over taxes stock electrical stuff so when going to more amp output, you're pushing the limits of the elec. systems ability to deliver power without frying wires.
My 140 amp. powermaster would have left me burnt down on the side of the road long ago if I had used the stock wiring.
