installing crank bearing
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
slant, it is not finished drilled for the bushing, so I plan to use the bearing. Does it require any "threadlocker" I guess it is just pressed in?
Tap it in and your set.
That's what I figured. I always had acces to a good friend that ha a machine shop. He took care of the crank issue,....I do not have a 1/2 inch drill and figure that is what I would need to enlarge the crank for the bushing, and then have to hone it with ?????? So no doubt the bearing is fine !!! thanks for the info.
