I got a mopar performance gasket kit with my used eddy performer intake. What are the yellow plastic inserts for? and how best to install the block off plates? Thanks.......
To add as well, if you haven't already done so, you may want to grind off the dowel pins at the end of the intake. I found out the hard way what happens. I am now looking for a new intake as the old eddy performer is cracked about 2". Which is kind of ok as I am in need of something a little higher in the rpm range.
