73-340 Well-Known Member Joined Apr 3, 2010 Messages 153 Reaction score 0 Location Delavan,il Aug 10, 2010 #1 just got this intake and has no bypass fitting . anyone have any solutions?
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,969 Location las vegas Aug 10, 2010 #2 drill and tap... or plug water pump end of bypass...
cudadriver Well-Known Member Joined Jun 14, 2004 Messages 752 Reaction score 1 Location Winnipeg, Manitoba, CANADA Aug 10, 2010 #3 Can you use one of the two holes with the square plugs as the bypass?
Tony Fields That's How I Roll Legendary Member Joined Aug 8, 2006 Messages 8,671 Reaction score 336 Location Columbus, Indiana 47201 Aug 10, 2010 #4 Drill and tap
D dodge freak Well-Known Member Joined Nov 5, 2006 Messages 3,988 Reaction score 78 Location Too close to Detroit, lol Aug 10, 2010 #5 cudadriver said: Can you use one of the two holes with the square plugs as the bypass? Click to expand... That is what I was thinking. No need for that form bypass hose then. If the fitting is too small easy fix I found, a 1/2 hose just over the fitting allows for a 3/4 hose to slip on tight. Sure you could drill and tap but why if you aren't using both those other hose taps.
