Intake gaskets for a 5.9 using an LA intake?
TrailBeast
AKA Mopars4us on Youtube
Arizona
Is there any reason for one gasket set over the other for an LA intake on Magnum heads drilled for it?
I kind of like the extra material of the mag gaskets, but also like the cleanliness of the LA gaskets.
But is there something I'm missing as to one over the other?
Thanks
I used Mr Gasket LA gaskets,worked fine second time around. Used the Fel Pro Stock Magnum OEMs,first time. If I did it again,Mr.Gasket ,or Edelbrock intake sets.
Thanks Tim.
So is there a reason you wouldn't use the blue Felpro LA set?
Not really,just personal.
I have always liked them and had good sealing with them.
That and I think they will be cleaner once installed due to less unneeded material sticking out everywhere like the Mag gaskets.
