I will say some of us get lucky using the cork seals,I sure have in all my builds.I always lay a small amount of sealant than the gasket than some more sealant and lots in the corners let set up for 15 minutes slowly tighten down here and there for the next 2 hours so nothing slips,now from what I think one should do is to not start up for 24 hours,let all dry real good.
That's kinda the same method I use, no leaks so far. Knock on wood (head), lol.
I also do the same on the oil pan.See in the pic how there was a little squeezed out I than run my finger down the side of the pan and block,just like caulking along you tub to get a great seal.Each to his own.
