as i recall the Team G intake has a big indent into the port for the intake bolts.
That's been proven many times not to impede flow.
hi, question time!! are they flow testing one port at a time or whole manifold upside down on bench?? just curious.
One port at a time. I only posted the average for simplicity. They offer the scatter numbers on their site.
Rusty, They flow better on hughes bench, they performed better in the Mopar Muscle test. Use whatever you want. I'll take floww numbers that jive with someone elses dyno numbers all day.
I myself have seen the perf RPm and the Victor beat the SP indy dual plane intake on a dyno. This jives with the issues hughes found.
Anyone selling parts or services has money to be made. However, if the money you make comes from max performance, you aren't going to lie about which intake is better.
Even further on this note, I've talked to 4 different head porters thus far in my journey towards getting my heads and intake ported. Evey one of them recomended either keeping my Perf RPm or swapping it out for a Victor. Are ALL OF THESE GUYS STUPID OR GETTING GREASED?
Follow along one more time with me......if you can.
Again, I never said the Eddy stuff was NOT better. My whole point is that the Weiand stuff ain't the JUNK that Hughes paints it to be. Period.
anything for the mopar single plane one?
Here is a little test we performed.
While we were working on an Edelbrock RPM head, we took a break to test it with some manifolds and an 850 cfm Mighty Demon carburetor. 1st column is the OOTB Edelbrock RPM head, 2nd column is the RPM head after some blending and the following columns are the indicated OOTB intakes all using the same 850 Demon. The M1 is a single plane and the 4bbl iron is from a '69 Road Runner
Lift....OOTB RPM...blended...stock iron...RPM....Torker II...M1....Victor
.100.......70...........72...........69...........71.........71........72.......72
.200......143..........150.........131.........145........148......148.....150
.300......201..........212.........172.........195........201......201.....202
.400......243..........254.........187.........228........242......234.....240
.500......271..........276.........199.........240........254......254.....261
.600......285..........290.........203.........251........264......266.....271
.700......293..........302.........204.........256........269......273.....280
.800......295..........315.......................261........273......276.....285
These flows should be lower. I believe the Hughes flows were through the manifold only.
I'm not sure that I made it clear. These manifold flows are through the head and carburetor. By comparing them to the flows through the head you can see the flow loss through the manifold and carburetor.
I just got thru porting a victor manifold for a 440 and the 4 corners of the plenum were very shrouded and with the carb on the manifold all 4 barrels were at least 1/4 shrouded. I had already looked at the chevy BB victor and several others that were wide open with no shrouding at all. This manifold now has a nice blended entry with no shrouding and sure does look better to me.I'm not a flow bench but I'm not blind either. I have no idea why Edelbrock would make that manifold like that.
Here is the bad news. We have dyno tested the Victor intake you just opened up and you just lost horsepower unless you use a spacer and rev the engine to 6,500-7000 rpm.
IQ52, speaking of spacers. In my dyno testing I made 10-15 more HP on the Eddy RPm when I used a 1" HVH super sucker spacer.
Have you ever tried one of these on a VIctor?
All this is very fascinating. What I need though, is a link to the Hughes site so I can find the compare for the smallblock manifolds. Does anyone have the link?
Such a link, on Hughes' site, does not exist for small block intakes. Let your fingers do the walking on Hughes website.
the intake bolt (pinch) that is referred to, ain`t that much on mine. and, I`m wondering ,if it`s a fuel separation issue, would it be lessened w/ a throttle body f.i. system??
Every combination is different and you have to try what you have access to, or be willing to buy and experiment.
I have never tried a 1" spacer on a Victor intake. I gain on a Victor when going to a 2" spacer but I gain a greater % on a single plane M1 than I do on a Victor. I didn't gain enough to spend the money when I used a 2" spacer on the Super Victor for the 426 small block.
