Michael Harrington
Neat set up. Edelbrock D64 manifold. Looks like a factory Hemi air cleaner assembly?
Yep, Hemi parts.Neat set up. Edelbrock D64 manifold. Looks like a factory Hemi air cleaner assembly?
Most likely for distributor clearance. 65'What? New KnN air filter. What's with the chunk missing out of it?
No doubt.The air cleaner assembly may have had great value by itself but cutting it up? Ouch!
On my mini tubbed Dakota I recently did the intake manifold plenum plate re seal. While the keg was removed I set my Offenhauser dual quad on the 5.2 as well as a Weiand Tunnel Ram. The 273/318 Offy probably will work great with OEM Magnum heads. The Magnum heads have smaller intake ports than the LA340/360. The intakes designed for a 273 don't have enough cast in meat to seal appropriately on the LA 340 port.In fact when the Roots Blower manufacturers would convert Offy intakes into LA blower manifolds they first welded up the flanges and partial port to build up and have sufficient material to seal.
4spdragtop that is a great looking 273.
The oOffy and probably the Edelbrock dual quad manifolds were specifically made for the 273 only. When the 318 came along it worked on those because the heads were the same. But no one tooled up and made a low profile under hood dual quad for the LA340 when it came out. Thats a shame. A dual quad airgap for the 340/360 heads would be awesome. I passed on the Modman. With its dual quad top, it looks wonderful. But really, it's a cavernous vast wide-open plenum manifold best suited as a blower manifold. Bolting on the dual 4 top looks great but from what I read not good on a moderate performing street engine.
I'm not real familiar with small blocks.I bought same NOS dual quad thinking I could use on my 340 build(x heads)....not a chance lol. Like you said the outside of the flange vs the port, you could see daylight lol. So it went on 273 for a short stint lol.
I love the looks of them.
Intake gasket is Felpro 1213, 340 size.
Are those port pictures right side up, or upside down?
in other words, are the 340/360 ports taller than 273/318, and slightly wider??
I have a tm7 440 manifold that has had a slug of aluminum added to the top of the port, to work on a max wedge head. Top of the port with added material is fine, bottom of the port, the manifold is razor thin.
