Marcohotrod
I like the purolator. I saw a dyno test with an old k + n down 90 horse, the cotton fibers get matted down. Another dyno test the best was Green filter
Thats how youtube videos of comparison testing should be done. No bs blathering about irrelevant nonsense as if the narrater is some legend in their own mind youtube wanna be star. Get to the info with good fast paced editing. Viewer gets in and gets out with the knowledge! Very refreshing after having to suffer way to many of the aforementioned videosWow, My head is scrambling.That guy packs a lot of info into a short video. Good information though. Thanks for the link
You can’t test any air flow not using a standard test pressure. His Mickey Mouse test rig can’t flow enough air to even give repeatable test results, let alone move enough air.
If he used an actual flow bench for the testing and picked a test pressure of at a minimum of 10 inches the results would be different. Then he could have tested at higher test pressures and recorded the results.
Poor testing capabilities gives inaccurate results. You can bet the engineers who design and test these filters move way more air through them at much higher test pressures than he did.
Do I dare disagree with the great yellow rose?? Na I will wait for @j par to do it! Haha I think that setup is acceptable for a demonstration like that. I may be wrong but not usally!You can’t test any air flow not using a standard test pressure. His Mickey Mouse test rig can’t flow enough air to even give repeatable test results, let alone move enough air.
Wtf you disagreeing with me for? You are supposed to disagree with him! HahaDo I dare disagree with the great yellow rose?? Na I will wait for @j par to do it! Haha I think that setup is acceptable for a demonstration like that. I may be wrong but not usally!
Higher test pressures would only make all of them leak more air----------------
So doing a test with a system that can’t even come close to moving air like an engine (even a flow bench can’t duplicate that but his little vacuum or whatever is ridiculous) and isn’t even close to what the filter sees when running.
The interesting thing about changing test pressures and using as much depression as you can (or...reducing the depression when sorting out flow issues) is air doesn’t behave the way one would think it does most of the time. It behaves like a liquid, except it’s compressible!
So yeah, no air volume and very low depression means his test is meaningless for the most part.
Drive around town with your windows down all day and see how much dust is on your dash. That is lapping compound eating your piston rings and bearings. Yeah I used to think that way when I was young and ignorant.I do not care. I still will use K and N, I mean how clean does the air going in an engine really have to be? IMO this test is not real life testing....
Interesting; I rode a 500 quadzilla and 250 quadracers out in the desert for 4 yrs., running K-N air filters, no foam over them, the secret to them is ''almost dripping'' w/ oil/trans fluid .' Never found sand in the intake or engine , the highly modifyed air box always had sand in them ---------
