internal/external & nuetral balance flywheels
OUTLAW
Master of All Mopars
Des Moines Iowa
I need some clarification on a few points about flywheels.
#1 is ... is the flywheel for internal balanced engine the same as nuetral balanced?
#2 I know 360's are external balanced how much does the harmonic balancer contribute to the balance?
#3 on a 318 is it nuetral balanced flywheel or being internal balanced motor does it still have a balancing effect on the motor? (i have seen them with drillings on the back )
thanks
#1 Yes
#2 It's unique to the 360 in SB terms
#3 The drill hole may be to get it neutral balanced. It should spin clean with nothng attached to it.
my ? is if you get external balance flywheel the t converter can be a nuetral one correct?
on a 360
